Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine shutting down at random.
Old 03-20-2012, 06:24 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
The pur wire is the 12v input to the starter soleniod "S" terminal which functions the soleniod to make the starter turn etc...
There was a lt yellow from the "I" terminal on the soleniod to the pos post on the coil
There was a black wire/cable from the battery to the starter.....now they are red and is the pwr source for the starter.
The resistor wire should be a wht wire that's spliced into a orange/pur to the pos post on the coil
If you're running an HEI you don't need the wht-pur/org or the yellow wires
