Engine smokes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2011, 11:57 AM
Engine smokes
Hey Guys ,
I have a 350ci SBC in a 1930 ford coupe. A while back I was noticing engine Hp loss. And One evening me and a buddie were tinkering with my car we could here what sounded like a loose rocker or so. But we were looking into another problem so we cut off the engine. Then when I started it back up there was a god awful noise coming from the top end of the engine.So I instantly turned it off. The Next day we tore into it and several rocker arm nuts had backed way off several of the studs and one valve pushrod had even came out from under the rocker arm and had bent the pushrod broke the pushrod guide plate.these are Edelbrock 6089 RPM Performer heads and guide plates. So we checked out the others they appeared fine so i orderd replacement push rod and guide plate. We reassembled it and now when I started it runs real rough and when I give it gas it has quit a bit of white smoke.I just did a compression test last nite. I didnt do it as sugested I was told to bring engine to operating temp then do the test. I dont want to run it that long knowing something is wrong so I just pulled the ignition coil wire and and then pulled each plug checked it then reistalled it then went to the next cylinder I turned the engine by key .
1-110 lbs 2- 93 lbs
3-101 lbs 4- 93 lbs
5- 60 lbs 6- 76 lbs
7- 110 lbs 8-85 lbs
I am yet to check the oil I am going to drain it tonight. to see if its milky from coolant.What do yall think the problem is could that of messed up the rings ? or is it likely just blown head gaskets due to valves not opening?Give me your ideas.
Old 05-04-2011, 12:30 PM
DoubleVision's Avatar
During the compression check did you do the check with the throttle wide open and the coil wire off? If so and the numbers are that low, it`s rebuild time. I`m also curious what brand of rocker arms did you use and which locking nuts? there`s also the possibility the cam has a couple of lobes gone.
Old 05-04-2011, 01:17 PM
DoubleVision
I did not have the throttle wide open it may of been slightly cracked is that better or worse? I just have roller tip rockers not full roller from Comp Cam with there locking nuts.
Old 05-04-2011, 01:34 PM
badknuckles's Avatar
you talkin to me?
Could have bent a valve and even possibly cracked a piston. Had that happen
Old 05-05-2011, 11:08 AM
to the top
Engine still smokes deno Engine 20 02-17-2006 10:48 AM
Engine Smokes/Rattles? TonyMac Engine 5 11-24-2005 12:29 PM
Engine Smokes like Crazy....Help! ice_cold_flame86 Engine 11 10-02-2004 12:56 AM
new engine smokes and stumbles redracer64 Engine 4 09-02-2004 04:57 PM
engine smokes and stumbles redracer64 Engine 1 09-01-2004 10:46 AM
