-   -   engine smokes (http://www.hotrodders.com/forum/engine-smokes-205235.html)
stallion0606 09-10-2011 05:08 PM
engine smokes
355 sbc smokes in town but not at highway speeds
DoubleVision 09-10-2011 05:17 PM
Likely at highway speeds you simply can`t see it. This could be valve seals, valve guides or a leak at the intake gaskets. Worse case scenario would be rings.
327NUT 09-10-2011 05:35 PM
How many miles on the engine...if you know?
stallion0606 12-28-2011 08:32 PM
was rebuilt in 2004. ran it in mudd boggs and ran hard till 2008 when it ran hot and started smoking afterwards
stallion0606 12-28-2011 08:34 PM
do not know how mant miles. speedometer stopped working
stefanP 12-28-2011 08:54 PM
Overheated engine is never good sign.Look at your spark plugs.Also take a compression test.On the other hand,"A engine that smokes is well lubricated!" ;)
bondo 12-29-2011 09:09 AM
Ayuh,... Do a compression test, 'n leak-down test...
Sounds like she's pretty Beat though...
stallion0606 08-02-2012 06:16 PM
disassembled engine. did a leak down test, not good. afterwards found that the valves looked like they tried to go through the heads, can these be repaired
Mojo56 08-02-2012 07:42 PM
A machine shop can install new seats in the heads...
