engine smokes - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2011, 05:08 PM
engine smokes
355 sbc smokes in town but not at highway speeds
Old 09-10-2011, 05:17 PM
DoubleVision's Avatar
Likely at highway speeds you simply can`t see it. This could be valve seals, valve guides or a leak at the intake gaskets. Worse case scenario would be rings.
Old 09-10-2011, 05:35 PM
327NUT's Avatar
How many miles on the engine...if you know?
Old 12-28-2011, 08:32 PM
was rebuilt in 2004. ran it in mudd boggs and ran hard till 2008 when it ran hot and started smoking afterwards
Old 12-28-2011, 08:34 PM
do not know how mant miles. speedometer stopped working
Old 12-28-2011, 08:54 PM
Last journal entry: 41 chevy frame on the move.
Overheated engine is never good sign.Look at your spark plugs.Also take a compression test.On the other hand,"A engine that smokes is well lubricated!"
Old 12-29-2011, 09:09 AM
bondo's Avatar
Ayuh,... Do a compression test, 'n leak-down test...
Sounds like she's pretty Beat though...
Old 08-02-2012, 06:16 PM
disassembled engine. did a leak down test, not good. afterwards found that the valves looked like they tried to go through the heads, can these be repaired
Old 08-02-2012, 07:42 PM
Hot Rod Has Been
A machine shop can install new seats in the heads...
The Following User Says Thank You to Mojo56 For This Useful Post:
stallion0606 (08-04-2012)
Engine smokes Eastex Jr Engine 4 05-05-2011 12:08 PM
Engine still smokes deno Engine 20 02-17-2006 11:48 AM
Engine Smokes/Rattles? TonyMac Engine 5 11-24-2005 01:29 PM
Engine Smokes like Crazy....Help! ice_cold_flame86 Engine 11 10-02-2004 01:56 AM
new engine smokes and stumbles redracer64 Engine 4 09-02-2004 05:57 PM
