Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine spec - hp estimate
Old 07-10-2012, 05:03 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
My thoughts are... with that valve size and heads not fully ported, he is 100hp too optimistic,... with even the best Super Stock port job at that valve size he is 40-50 hp optimistic.
A set of Dart 215's or similar heads that will flow somewhere close to 250cfm at .550" valve lift on the intake and his guess would then be closer to correct.
The Following User Says Thank You to ericnova72 For This Useful Post:
gflentge (07-10-2012)
