Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine spec - hp estimate
Old 07-10-2012, 06:11 PM
gflentge gflentge is offline
Originally Posted by ericnova72 View Post
My thoughts are... with that valve size and heads not fully ported, he is 100hp too optimistic,... with even the best Super Stock port job at that valve size he is 40-50 hp optimistic.
A set of Dart 215's or similar heads that will flow somewhere close to 250cfm at .550" valve lift on the intake and his guess would then be closer to correct.
I was estimating around the 400 mark.....
What di you think about a set of ported Sportsman II on same combo....?
Also, that cam seems big....
