Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine spec - hp estimate
Old 07-12-2012, 10:29 AM
gflentge gflentge is offline
Originally Posted by ericnova72 View Post
Ported Sportsman II's could be as good as the newer 215's, just depends on how good the port work is.
Cam sound like it is intended to turn up to 7000 rpm. Would be a lot easier to tell rpm range from the .050" duration, and whether it is a solid flat tappet, hydro flat, or roller.
Is a hydraulic roller cam.... The seller either doesn't have 0.50" duration or isn't telling.....
And thats why I thought the cam was big....7k with those heads?....sounds like it would run out well below the 7k
