engine spec - hp estimate - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2012, 03:50 PM
Been reading for a while and see all sorts of posts on HP estimates based on engine spec/build sheet. Been to "ryans" info page and the onfo is great, but there are always unique things .....
Found a 383 already built (someone elses project that they ran out of time/$ For) with following spec and would love to hear opinions on build and estimated hp
Seller says motor was built to make big HP upwards of 480hp and big torque over 500with no spray.... i don't see it, based on the spec hes giving
Any input is great.....good/bad/estimates/opinions...
Specs are.
Intake: Ported Victor Jr.
Carb: Hollwy 750 double-pumper
Heads: Fuelly - 194/150 valves Manley Undercut & Swirl Polished 3 angle valve job ARP Head bolts
Crank: Eagle Cast Steel,3.75" stroke
Rods: Reconditioned GM pinks w/90,000 psi tensil straight bolts
Pistons: Speed Pro Forged and skirted (.125" domed,4.030" over)
Cam: Duration @ 295/305 (roughl) Lift @ .575/.585 w/1.6 hydraullic roller rockers
Rockers: Proform 1.6 full roller rockers
Pushrods: Comp High Tech,stock length
Lifters: Crane,anti pump up
Current Distributor MSD HEI with module and high output coil
Long tube headers
Thanks for input
G
Old 07-10-2012, 04:03 PM
ericnova72's Avatar
More for Less Racer
My thoughts are... with that valve size and heads not fully ported, he is 100hp too optimistic,... with even the best Super Stock port job at that valve size he is 40-50 hp optimistic.
A set of Dart 215's or similar heads that will flow somewhere close to 250cfm at .550" valve lift on the intake and his guess would then be closer to correct.
The Following User Says Thank You to ericnova72 For This Useful Post:
gflentge (07-10-2012)
Old 07-10-2012, 05:11 PM
I was estimating around the 400 mark.....
What di you think about a set of ported Sportsman II on same combo....?
Also, that cam seems big....
Old 07-11-2012, 11:48 AM
ericnova72's Avatar
More for Less Racer
Ported Sportsman II's could be as good as the newer 215's, just depends on how good the port work is.
Cam sound like it is intended to turn up to 7000 rpm. Would be a lot easier to tell rpm range from the .050" duration, and whether it is a solid flat tappet, hydro flat, or roller.
Old 07-12-2012, 09:29 AM
Is a hydraulic roller cam.... The seller either doesn't have 0.50" duration or isn't telling.....
And thats why I thought the cam was big....7k with those heads?....sounds like it would run out well below the 7k
Old 07-12-2012, 02:57 PM
ericnova72's Avatar
More for Less Racer
I agree... With those heads power is going to go flat at 5500-5800 rpm.
Those heads are just killing what potential the short block has. They would make a good low rpm torque truck motor head, but everything in the 12.5-1 compression short block looks aimed at a 3000-6500+ rpm performance target.
383, chevy
ID & Spec my engine Pst'n'Brk Hotrodding Basics 0 01-20-2009 01:25 PM
Engine Build spec, how do you get yours Jsup Engine 13 12-21-2008 05:44 PM
Spec's on 4.3 chevy extreme engine grumpy1 Engine 4 12-26-2007 09:07 PM
350 MC Engine that needs spec'n ChrisMiddleron Engine 7 03-19-2006 04:49 AM
oem engine spec. info wayfast77 Engine 1 02-24-2006 11:23 PM
