engine sputters at around 4500 RPM - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2004, 05:48 PM
I dun learned sumthin
Well i just recently got my new engine together. On its first road test it did good but i get a little backfire out of the exhaust and loss of power.
Here is the set up
MSD 6AL
MSD pro-billit HEI
Brand new short block
Trick flow 23 degree heads
Comp cams Magnum 12-212-12
Victor Jr. intake
Speed demon 750 DP
High flow fuel pump
I think that the mechanical advance springs are possibly to stiff and not allowing the advance to go up fast enough. this would retard the timing and so the fuel mixture would not be completly burned when it goes to the headers causing the back fire.
Just a theory. What do you guys think?
Old 07-17-2004, 06:24 PM
lluciano77's Avatar
Check your advance curve with a timing light and a tach.
Old 07-17-2004, 07:26 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Back firing through the exhaust is caused by a few things. Header leaks, timing or improperly adjusted idle slots.
