-   -   Engine Squeak :( (http://www.hotrodders.com/forum/engine-squeak-163938.html)
BowTiePride 08-25-2009 12:24 PM
Engine Squeak :(
There is a squeak that sounds like it is at-par with engine speed. It's a 355 (350 bored .030 over), with mild performance additions (I can explain if necessary), and a 2speed powerglide trans, in a 67 Impala 4dr. I was told that it might be the flywheel but I thought I tightened the bolts on damn good. Any ideas? Thanks a million, she's my daily driver and it's driving me crazy!!!!
ssmonty 08-25-2009 04:24 PM
Get a 2ft piece of tubing small enough to fit in your ear to localize the sound.
Your flywheel may be a bit warped and rubbing on something.
ssmonty
BowTiePride 08-25-2009 09:39 PM
Hmmm, I shall check that tommorow!! If I'm in drive with the brake on, and elevate the idle by pressing the gas slightly, it will go away
dawg 08-26-2009 05:06 AM
flexplate should be torqued down btw.
not just wrenched down.
Are you sure it not a glazed fan belt?
BowTiePride 09-02-2009 11:31 PM
It definately wasn't a fan belt, and wasn't flywheel either :( but I guess that's a good thing! It was my transmission sifter linkage. There's a part attached to the transmission that's spring loaded, and the shifter linkage was squeaking against the trans, so I cut a thin square out of a plastic coffee tin lid and slid it between. Squeak= no more :")
