Engine Stalls - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2006, 10:31 PM
Engine Stalls
I Have A 94 Jeep Cherokee That Will Just Quit Going Down The Road ,and Will Sometimes Start Back Up On Its Own And Sometimes You Have To Pull Over And Wait Awhile To Get It Started. Does Anyone Have A Clue What Could Cause This.
Thanks.
Old 10-19-2006, 09:40 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I would look at the crank position sensor, I can assume that its a 4.0l engine,
The CPS is located at the back of the engine block, right where the trans bell house bolts to the block, located center to the drivers side a little on the bell housing, it sticks down and reads the sensor ring on the flex plate, very common failure rate on this part.
Steve
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Rotella Motor Oil boss350 Engine 14 04-17-2007 11:00 PM
1997 Ford Thunderchicken....engine stalls... BillyBob1950 Engine 7 12-12-2002 06:32 PM
