Engine stalls - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 08-28-2012, 12:41 PM
Engine stalls
95 chev 350 crate engine about 8000 mi . Just started stalling when stopping or shortly after moving. Fires right back up. Runs fine at speed. I have no code reader. I'm thinking idle speed senser Any thoughts?
Old 08-28-2012, 05:02 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Idle speed sensor? ?? no such critter .
However if you have a check engine light you should see what the code is.
You might just need to set the minimum air rate is all. Just google it. There are a couple places that explain it well.
Fact is stranger than Fiction
Old 08-28-2012, 06:16 PM
mass air flow sensor
Old 11-18-2012, 09:28 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
how about letting us in on what its in? Carbed? TBI? trucks , car? wheelbarrow? auto, standard?
We need more info.
Old 11-18-2012, 10:26 AM
gearheadslife's Avatar
MentalMuffinMan
95 crate, if it's in a 95 g.m. you don't need a code reader, you can jump term a&b on the adel connector and it'll flash the codes on the dash in morse code..
Old 11-18-2012, 02:14 PM
EagleMark's Avatar
GearHead-EFI.com
Yup, easy with instructions and GM PDF for engine codes here:
GM ECM Reading Error Codes CEL-SES Light
Old 11-18-2012, 04:00 PM
Guess I should have gotten back sooner, I fixed it right away. Turned out to be the ignition switch. 95 Chevy pickup. Guess they're a problem. All four or five parts stores in our small town sell an average of 8 a year. Talk about a price difference. A high of $275 to $140 with my disscount. I got one off e-bay for $47 delivered next day and free freight.
Recent Modern Electronic Engines posts with photos
Engine stalls coolcars58 Engine 1 03-27-2009 06:16 AM
Engine stalls.. Dschaefer Engine 4 07-15-2008 12:40 AM
Engine Stalls miclewis Engine 1 10-13-2006 09:41 AM
engine stalls say10tatoo Transmission - Rearend 2 08-14-2005 12:00 PM
Engine stalls Jessy James Engine 20 10-26-2004 02:59 PM
