We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 08-14-2005, 01:49 AM
say10tatoo's Avatar
say10tatoo say10tatoo is offline
New Member
engine stalls
I just bought a 65 corvair ...it starts fine and idles good...it accelerates in nuetral fine....when I drop it into drive or reverse the engine stalls and dies...is this the torque converter not working or is it some else?
Old 08-14-2005, 11:48 AM
poncho62's Avatar
poncho62 poncho62 is offline
poncho62's barnstar
Wiki editor
Wiki Edits: 5
Could be.....can you keep it running at all in gear.....by playing with the throttle or anything?
Old 08-14-2005, 12:00 PM
say10tatoo's Avatar
New Member
engine stall
the minute it goes in gear it dies....I got an interesting answer on a corvair site...
Hi Greg,
I believe this is commonly caused when the idle is too high when the timing is set. This causes the vacuum advance to kick in when the timing is set. When the vacuum advance kicks out in gear, the timing retards and the engine dies. Just try lowering the idle speed to spec THEN set the timing.
You could also "adjust" the vacuum advance cannister if it is kicking in too soon due to a weakened internal spring. Use a hand vacuum pump and see at what vacuum it starts kicking in. It should be about 8-10 (as I recall) but most are 5-7. Perform a search here for "vacuum adjust" or "calibrate vacuum" for all dates and see what you find. It has been posted many times before here. To calibrate, just remove the vacuum advance module and with a long 9/16"-inch socket, band on the end. This compresses the spring and moves the initial vacuum actuation point higher. Matt likes to have his around 10.
-- Larry
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "engine stalls"
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
the history of chevy v8's savman1 Engine 30 01-25-2008 01:02 PM
ENGINE BALANCING NAIRB Engine 10 12-28-2002 06:09 AM
1997 Ford Thunderchicken....engine stalls... BillyBob1950 Engine 7 12-12-2002 06:32 PM
