Check for vacuum leaks around the carb........Timing may be off, ....any number of things.
Ontario Rodders |
Engine stalls in gear
It is a 68 Firebird w/69 YH428 bored 30 over, Edelbrock Performer RPM heads 87cc, Lunati Bracketmaster II 230/230 @ .50 .490 lift LSA110 degreed @ 104, Edelbrock Torquer II with a Mighty Demon Blow Thru 750, Hedman Hustler Headers and an ATI Procharger set at 5lbs.
I have checked for vacuum leaks and found none. The tranny is a built GM 350 with a B&M 10" Hole shot 1800 stall converter. The idle is set at 1200 in neutral but can't set in drive because it won't idle. |
Not enough converter. You need 1000 more rpms of stall for that cam.
I bet the timing is low. That cam needs 20 degree at idle. with force induction, I would just lock the timing at 20 to 24 degrees. You also need a 3.55 to 3.73 gear. |
Posted by azbandit:
"I have checked for vacuum leaks and found none." Check this out...... http://www.crankshaftcoalition.com/w...ak%2C_internal |
The timing is set at 6 degrees with 34 total @3200rpm. The rear end is 355 posi 12 bolt. Its been at these specs for 3 yrs. Rebuilt top end due to blown head gasket 6 months ago. Always ran like a raped ape. Until 3 months ago.
I misstated the size of converter. It is a B&M super holeshot 2400. That is an interesting article Techinspector. I'll have to look into that. Thanks everyone.
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| engine stalls with 700r4 | gmwillys | Transmission - Rearend | 3 | 08-13-2005 01:33 PM |
| New Engine Built & Dyno'd | babe_n_indy | Engine | 69 | 09-09-2004 07:26 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
| the best engine parts, chain vs. gear, engine combos | jollygiant_57 | Engine | 6 | 05-01-2002 09:34 AM |
