Engine stalls under hard braking - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2012, 03:05 PM
hello
i finish to convert my 71 nova to disc brake (only the front )
during the test driving i noticed : running fast and trying to stop the car asap make the engine stall , and its difficult to start the engine right after
i also noticed , way before the convertion , wild turn or donuts attempt make my engine stall as well , and the same , its difficult to restart the engine
any idee? thanks
my engine start every first crank in general , even if i dont use it for two week
350 with edelbrock 650 cfm
power steering
Old 11-22-2012, 03:11 PM
techinspector1's Avatar
Wiki Edits: 326
My best guess would be the float level in the carb bowl is too high. Also monitor fuel pressure for max 5 psi at the bowl inlet.
Old 11-23-2012, 07:26 AM
Tech, everyone appreciates you.
T-350, what happened to engine braking? bygddy Transmission - Rearend 10 11-04-2012 02:37 PM
Very Hard Braking! 27Tall T Suspension - Brakes - Steering 24 07-12-2011 09:29 AM
Engine wants to die when making sharp corner or braking hard and fast jmichaelre Engine 12 06-04-2010 01:25 PM
"73" Ford F-100 / Hard braking cowkicker59 Suspension - Brakes - Steering 2 03-04-2007 04:26 PM
no engine braking in th350 chayes6942 Transmission - Rearend 3 07-04-2005 01:18 PM
