engine stalls when hammered - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-20-2010, 07:21 PM
Originally Posted by eloc431962
Looks like you are getting close, I was just going to say i had one that done the same thing and it was a combination of timing and carb adjustment. Ok there's my 2 cents also.
Cole
Thanks that reminded me to try the different pump shots for the carb and see what happens. the thing runs like a bat out of hell now!
  #17 (permalink)
Old 09-20-2010, 07:22 PM
techinspector1's Avatar
Wiki Edits: 326
This may be a good opportunity for you to teach your son how to determine top dead center so that he can time the motor properly with a light.
http://www.crankshaftcoalition.com/w...op_dead_center
  #18 (permalink)
Old 09-20-2010, 07:24 PM
Ya i had him help me do this. he held the light while it moved the distributor and just double checked it. now we gotta get the total timing set
  #19 (permalink)
Old 09-20-2010, 07:31 PM
Maybe you shouldn't drink so much!!
Sorry, couldn't resist
  #20 (permalink)
Old 09-20-2010, 07:34 PM
Wiki Edits: 326
Your answer tells me you didn't read the link I provided you. Whatever.
  #21 (permalink)
Old 09-20-2010, 07:43 PM
i read it i meant that i had him help with the timing, i showed him how to do that.
  #22 (permalink)
Old 09-20-2010, 08:22 PM
lol the truck is the heavy drinker
  #23 (permalink)
Old 09-21-2010, 06:22 AM
So whne I get the recurve kit for the dizzy do I wnat it to reach full advance sooner or later?
  #24 (permalink)
Old 09-21-2010, 06:42 PM
ericnova72's Avatar
More for Less Racer
As soon as the engine will tolerate without detonation. 2500-3000 rpm is a good point to shoot for, but if this is a heavy truck with big tires and not deeply geared it may have to be higher.
  #25 (permalink)
Old 09-21-2010, 08:01 PM
ya the truck is pretty heavy got just the standard old tires on there can't remember what size some nice a/t tires. and it's got like 3.42 for gears and cruises at 55 at like 2100 rpm
  #26 (permalink)
Old 09-21-2010, 09:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In this type of case, you'll be depending on the vacuum advance to provide you w/advance under light load and throttle settings. If you rely solely on the mechanical advance, you'll never have enough timing to allow for economical cruising.
BTW, if your tires are right at 30" to 30-1/2" tall, you're at about a 3.42 ratio running 2100 RPM @ 55. MPH.
  #27 (permalink)
Old 09-21-2010, 11:30 PM
so you are kind of saying that i need an adjustable vacuum canister? If I am understanding you correctly.
  #28 (permalink)
Old 09-22-2010, 07:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yes, unless you get lucky and the OEM unit has the right amount of advance built into it.
If you want to try a different advance can- and you have an HEI ignition- there are at least two that are readily available.
ADJUSTABLE VACUUM ADVANCE CAN KIT- Crane #99600-1, 99600-1 INSTRUCTIONS.
And the ACCEL #31035 is an adjustable vacuum advance can for GM HEI that allows infinite adjustment to BOTH the amount and rate of advance. Comes w/instructions and tool.
DETERMINING TDC will allow you to be sure the timing tab and damper are correct for TDC.
MAKE A TIMING TAPE to see what the total timing is, w/o needing to use a dial back timing light. Or buy one.
  #29 (permalink)
Old 09-26-2010, 10:54 PM
okay so i was not able to pick up the curve kit the other day. no one around me carries it and so i will have to order it off of summit of jegs. i noticed today after we got the exhaust installed (now it's quieter and you notice more) that when you raise the rpms up to 3000 and hold it for a few seconds it seems like it pops pretty good. i don't know if it's just the sound of the headers though. it's almost like it's missing if i think about it.
  #30 (permalink)
Old 09-26-2010, 11:24 PM
it sounds like we are having a similar problem. I installed a fuel pressure regulator and set it at 6psi (was around 10) set my timing at 14 deg btdc and that solved a good bit of my problem. I also changed my header gaskets and it solved my exhaust problem with popping. mine was when i accelerated then let off the gas though, not sure if that was the case for you.the only problem i have now tho is when i punch it it loads for a sec then takes off. have u checked what your fuel pressure is at? electric or mechanical pump?
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
Engine stalls when trans put into gear Sedan delivery dude Transmission - Rearend 5 11-25-2006 04:00 PM
Engine stalls off the line Pinko351 Engine 2 11-15-2006 07:12 AM
1997 Ford Thunderchicken....engine stalls... BillyBob1950 Engine 7 12-12-2002 07:32 PM
