engine stalls when hammered - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 09-27-2010, 09:00 AM
Originally Posted by F-BIRD'88
Recurve the distributor for 22 to 26 initial at idle and 34-36 at max advance (2800-3200)
shorten/limit the advance curve to 10-12deg to allow this.
The 280H cam needs this modified curve with increased idle timing.
A stock converter will not work well. Get a 3000 to 3500 stall and 4.10's
The 280H cam likes to rev. Its dead below 2500rpm.
Going to be upgrading the stall soon. so you are saying that i shoule set initial to 22* and get some stiff springs to keep mechanical lower in the degree range?
  #32 (permalink)
Old 09-27-2010, 09:38 AM
Originally Posted by 69chvyc10
it sounds like we are having a similar problem. I installed a fuel pressure regulator and set it at 6psi (was around 10) set my timing at 14 deg btdc and that solved a good bit of my problem. I also changed my header gaskets and it solved my exhaust problem with popping. mine was when i accelerated then let off the gas though, not sure if that was the case for you.the only problem i have now tho is when i punch it it loads for a sec then takes off. have u checked what your fuel pressure is at? electric or mechanical pump?
it's a mechanical fuel pump and i have never checked it out to see what psi it is running. you need to buy a gauge right?
  #33 (permalink)
Old 09-27-2010, 05:11 PM
First, determine how much timing is really required at idle (18-26deg) and how much is required at max advance. (32-38deg)
Then, limit the advance travel to allow this.
Some people lock out the advance system to help determine the best timing points
at the different rpm/load points.
To see the point:
Lock out the advance and set the locked timing at 34deg BTDC and go for a ride. (the timing does not move with rpm).
Now tear down the distributor and create the best curve.
Sounds a bit complicated, but doable. Would you by chance have any idea how to do this?, or if anyone else reads this you guys could help out too.
  #34 (permalink)
Old 09-27-2010, 10:52 PM
yea I picked up a fuel pressure gauge from jegs and an inline adapter and hooked it up midway from the fuel pump and the carb. I then bought a fuel pressure regulator and set it at 6psi bc I heard that whats holleys run best at but you said you have an eddie so im not sure what they should be running at. I wish I could help you understand the timing but im kinda in the same boat you are with that. good luck!
  #35 (permalink)
Old 09-27-2010, 11:03 PM
techinspector1's Avatar
Wiki Edits: 326
5 1/2 max on an Edelbrock. 6 1/2 max on a Holley. There is no reason to run them right up against the limit though. Back off 1/2 psi as 69chvyc10 has done and leave yourself some room. 5 psi will work the best on a Performer/AFB carb.
  #36 (permalink)
Old 09-28-2010, 08:45 AM
Thanks for the info on the line setup and no problem i don't expect everyone to know everything because i sure don't.
  #37 (permalink)
Old 09-28-2010, 08:54 AM
Okau thank you. when i do get a pressure regulator i will set it to 5 psi.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Engine stalls when trans put into gear Sedan delivery dude Transmission - Rearend 5 11-25-2006 03:00 PM
Engine stalls off the line Pinko351 Engine 2 11-15-2006 06:12 AM
1997 Ford Thunderchicken....engine stalls... BillyBob1950 Engine 7 12-12-2002 06:32 PM
