Initial timing too low, or accelerator pump shot not big enough. Accel pump shot too small is a common problem with the Carter/Edelbrock carb design.
Being that you say it is fine from a slightly higher rpm, my bet is pump shot combined with the low rpm maybe causing slightly lower timing. Move the pump link to the larger shot hole and see if it helps. May also require a large pump nozzle/booster cluster to get the shot big enough. What are your initial and total mechanical timing figures? |
That 8004 intake is for a spread bore design carb there is it not? I am not sure but you need an adapter for the eddy square carb on these yes/no?, the spacer you are talking about needs to be verified, is there any type of transition adapter needed here? these miss matches (if there is one) can cause throttle response issues as well.
2 more of my cents |
Total timing is checked with a timing light by revving the engine and finding out the point the timing stops advancing and noting the degree and rpm reading. You will need a advance adjustable light, or a degreed timing tape on the balancer. Take a look in our Crankshaft Coalition Wiki for tutorials on making a easy degree tape for your balancer. Geting the timing set up right will be the biggest factor in getting the engine to run right and make good power up to its potential, and is the most common thing most young or limited experience rodders don't even know about.
The 280 cam is big enough it really needs to have initial timing in the 16-18° area, but you can't let the total get over 38° without risking getting detonation damage to the motor. Usually requires you to tear the distributor apart and limit its advance amount to get things right. You can search some of the recent timing threads here to get a taste of what is required. In gear idle seems a bit low, adding 100 rpm may really help you cover some of the problem, but distributor modification is what it really needs to be right.. Try testing 16-18° initial to see how it responds from a stop, but don't run it up the rpm scale far to keep it from getting too much total and going into detonation. Just brief bursts from a stop to see if you are working in the right direction on timing. |
If you punch it from a dead stop it'll stall or lose all power, but if you hold the break and push on the gas to get the rpms to 1000 and then let off the break while simultaneously smashing the gas it'll smoke the tires for atleast 30 plus feet.
yep the transition plate may help then
http://www.edelbrock.com/automotive_..._spacers.shtml but really I would consider a sqare bore intake and if you don't need it for clearance or something ditch the spacer altogether as it/they can give greif. Another option would be to go with a Qjet with that manifold, or a holley 4010 Qjet replacement carb but they were not so great, mine sits on the shelf. thanks for the note on the chevy. |
Here:
http://www.crankshaftcoalition.com/w..._a_timing_tape this topic/link gets more hits than a buck decoy at the rifle range, good luck and let us know how she goes 2 more of my cents |
Looks like you are getting close,
Cole |
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| Engine stalls when trans put into gear | Sedan delivery dude | Transmission - Rearend | 5 | 11-25-2006 03:00 PM |
| Engine stalls off the line | Pinko351 | Engine | 2 | 11-15-2006 06:12 AM |
| 1997 Ford Thunderchicken....engine stalls... | BillyBob1950 | Engine | 7 | 12-12-2002 06:32 PM |
