Engine Stalls when put in gear
I have a '63 caddy with an Edelbrock Performer carburetor.
The car ran fine the first year that the carb was on (last year)
Now when it warms up the car will suck all the gas out of the fuel filter, remain running just fine, but stall when put into gear.
However, once the car is moving, it will travel at any speed but will obviously bog under full load.
This only happens when car is at running temperature, the fuel filter and pump have been replaced, Timing and ignition as perfect. I notice excessive pressure coming out of the carburetor inlet hose when I disconnect the fuel filter. No vacuum leaks, all hoses are fine, there are no emissions devices on the car.
This problem has me completely stumped, please help!
