engine stalls when put in gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2010, 07:17 PM
BURN RUBBER NOT YOUR SOUL
my chevy 305 engine stalls as soon as i put it in gear dont know if its a trans problem or engine problem happen out of no where at a stop sign
Old 10-08-2010, 07:32 PM
Footstomper
Last journal entry: 40 ford/cadillac coupe
Warrick,
The 305 had been running fine? The transmission was fine? Have you worked on wiring on maybe kick down? It could be a relay, fuse or short. Just think if you had worked on to remember if you changed something. Or dragged hitting the linkages or wiring.
Old 10-08-2010, 07:36 PM
havent worked on anything on the car in months i replaced the torque converter and lock up witch did nothing stills stalls in gear then only way i can keep it in gear is if i push it down the road and put it in drive then it runs fine intill i have to stop when i do it stalls
Old 10-08-2010, 07:38 PM
oh btw its a 91 305 tbi with a th700r4 trans
Old 10-08-2010, 08:10 PM
sickolds's Avatar
sickolds
its the trans dude
Old 10-08-2010, 08:16 PM
i though so what wrong with it
Old 10-08-2010, 09:14 PM
Greg T's Avatar
www.krusinklassics.net
Sounds like the converter is locked up. Check the signal to the switch. It may be locked all the time.
Old 10-08-2010, 09:20 PM
Footstomper
I had a problem with my cadillac 500, with a stock TH400. My problem because I did not tune it right. It would go dead in park. Another thought, I found a dirtdab clogged the ventilation on the bellhousing. It was burping AT fluid. Did you tried replacing the module?
Old 10-08-2010, 11:36 PM
SSedan64's Avatar
You changed the Torque Converter and Lockup Solenoid in pan?
The ECM commands lockup, TPS & Brake switch signals are used for this also. Normally a bad Brake switch will only cause no lockup tho'. Brake lights & TCC Lockup use different sets of contacts in the Brake switch.
The Converter Clutch valve in the Trans Pump may be sticking/binding & not allowing the Clutch to disengage.
Location >> http://www.sonnax.com/announcements/77805-K.pdf
Another Pic >> http://www.rowand.net/Shop/Tech/imag...alWiring08.jpg
Right hole in Pump is TCC Valve location underneath TCC Solenoid.
Center hole is for Filter.
Left hole is Pr. Regulator, TV Boost & Low/Reverse Boost valves.
Old 10-09-2010, 10:53 AM
if its an alectrical problem causing unwanted torque converter lockup, try driving with the torque converter plug on the tranny disconnected. if the problem goes away then you have an electrical problem with it
Old 10-09-2010, 10:03 PM
SSedan64's Avatar
If it's Locking up in 1st & Reverse it wont be electrical.
There's no fluid available to the TCC Solenoid in 1st or R, only 2nd, 3rd & 4th.
Old 10-15-2010, 02:21 AM
its stalling in gear with or without the plug hooked up ill try to see if its a blocked passage
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Engine going dead when put in gear 46 chevy pickup Engine 9 06-12-2009 04:25 PM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 05:55 PM
engine turns off when the car is put in to gear t623 Engine 4 02-03-2002 09:23 AM
engine turns off when the car is put in to gear t623 Engine 4 01-24-2002 07:33 PM
