engine stand - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-18-2007, 02:32 PM
jray's Avatar
Most certainly stay away from the light-duty 3 wheel ones........I had a cheapy 3 wheeled one and after dropping an engine twice I found someone I didn't like and gave it to them!!
  #17 (permalink)
Old 05-18-2007, 03:25 PM
texastomeh's Avatar
I've got the 1,000# one and it did a good job on the 405 SBC that I just finished. I did cut a piece of 2x4 and use it as a vertical brace under the front end as I loaded the block with heads, water pump, harmonic balancer, etc.
I would probably buy the 2,000# one if I had it to do over again.
DO NOT buy the 3 wheel 750# one. Had a friend that tipped his over with a 350 SBC on it. Luckily, no serious damage (a storage cabinet stopped the fall), but sure scared the bejeepers out of him.
Good Luck!!
texastomeh
  #18 (permalink)
Old 05-18-2007, 06:16 PM
Mustangsaly's Avatar
my three wheel engine stand has gave No Troble since it was built in the 70s. but I watch the three wheel engine stand when I'm moving it.
Mustangsaly
  #19 (permalink)
Old 05-19-2007, 11:46 AM
texastomeh's Avatar
Now THAT looks like an engine stand!!!
I should have qualified my earlier remark by pointing out that he was moving the stand and engine when it tipped.
texastomeh
  #20 (permalink)
Old 05-19-2007, 04:07 PM
that lime green 350 hanging on the stand is for my sons Suburban, he picked and loves the lime green. I will put a tape measure on that one cause its tall. real tall for me torqin heads & intakes. my uncle made everything over size to fit him cause he was so big. I'm real careful moving that stand with a engine on it, but it rolls real nice even over floor dry and little pebbles. I just keep a eye open when me or my boy is moving it. it rolls nice with a big block buick on it that was the last big block on it. but for a 3 wheel monster it rolls nice. and it has big bearings in the neck, they look like wheel bearings.
Mustangsaly
  #21 (permalink)
Old 05-20-2007, 08:51 AM
onebadmerc's Avatar
I need a bucket of arc sparks
I bought a 4 leg 1000 pound stand from HF last year and bolted my Ford 460 to it with no problems. The stand flexed more than I liked it too but it held up fine. As with my 3 leg 750 pound stand, I will only store empty blocks on it after it fell over with a fully dressed 351C on it.
engine run-in stand jeff bonnell Electrical 23 01-16-2012 05:13 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Engine Stand Malibucdl General Rodding Tech 13 11-10-2003 11:18 PM
engine test stand plans ghostgunn General Rodding Tech 20 08-11-2003 09:24 AM
engine test stand chevynut General Rodding Tech 1 05-31-2003 02:50 PM
