Engine Stand - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2003, 05:31 PM
Malibucdl's Avatar
Laissez les bons temps rouler
Last journal entry: Frame Removal
Engine Stand
I will be rebulding the engine in my '53 Packard Clipper pretty soon. Right now the block, crank, and 6 of 8 pistons are sitting on a wooden stand in the garage. It is sturdy, but is not very easy to work on. Where can I find an engine stand strong enough to hole an inline 8cyl engine that will weight a little over 900 lbs. when completely built. I have looked at Jegs and Summit, but the stands that they have look like they are kinda short on bottom, and will tip over. I would like one that has all casters on bottom and spins 360* at the engine. Any suggestions as to where else I can look?
Chris
Old 10-31-2003, 10:03 PM
MI2600's Avatar
Member# 3287
I just checked EBay and they have 1250lb stands for $33 that have four casters and two legs going forward. DO NOT buy a stand with three casters..they tip.
Old 10-31-2003, 10:24 PM
pzatchok's Avatar
OddJob
Check harbor freight. Just picked up one there.
Old 10-31-2003, 10:29 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Or build it like a big rig and stand it on end.
Old 11-01-2003, 02:52 AM
I'd look long and hard at any cheaper engine stand before I put that chunk of iron on it. It's probably almost twice as long as a V8, therefore it will have almost twice the leverage as a V8 as it tries to bend/break/tumble the stand. My old 750# Chinese stand had a warning in the instructions not to use with an inline 6, I assume for that reason. I use a 1250# one now. If the 1250# stand will handle 1250# with the center of gravity 12" out from the mount plate, it would only handle (theoretically) half that with the COG at 24".
Old 11-04-2003, 10:15 PM
Malibucdl's Avatar
How would I go about doing this? What materials would I need to build it? Got any pictures or diagrams?
Old 11-05-2003, 12:40 AM
Might check a diesel repair shop & see what they use.
Old 11-08-2003, 06:28 PM
Oreif's Avatar
I bought the 1000lbs one, But they do have a 1250lbs stand.
http://www.buytools.ca/products/indu...ne_stands.html
Hope this helps.
Old 11-08-2003, 09:29 PM
pzatchok's Avatar
OddJob
http://order.harborfreight.com:9100/...ht/results.jsp
If you have to how about a 1 inch think triangle of plywood to hold up the front at the crank. Just cut a hole in it big anough for the crank to stick in and put a big washer and polt back in the end of the crank to hold it. That will at least keep it from bouncing as you work but you'll have to remove it to move the engine around.
Old 11-09-2003, 07:02 PM
Malibucdl's Avatar
Thanks guys for the responses
But, all those stands are for V8s. I dont think that they will handle a straight 8, without tipping. And that would be a problem, cause I can't pick this thing up by myself. Heck, it took 5 guys counting me and the movers to get it to our new house. I do like the idea of standing on end though.
Chris
Old 11-10-2003, 06:59 PM
roys63's Avatar
Buy 2 and put one on each end, this will be the safe way and not have your engine hit the floor or you.
Old 11-10-2003, 07:22 PM
406chevelle's Avatar
One of these days...soon
WOW an inline 8, that would be a problem with all the stands I have seen, I think I would buy 1250lbs stand and modify it to hold the length of your motor.
Be careful what ever you do.
406chevelle
Old 11-10-2003, 10:01 PM
Here's a one-tonner for $100
http://www.menintools.com/shop/es2000.html
and here's a diesel stand for $250
http://www.toolscomplete.com/d/Diese...and_860826.htm
Old 11-10-2003, 11:18 PM
NorthStar's Avatar
Heres a few heavy duty stands.
Ive used the Revolver quite a bit I guarantee that will handle your engine but you would have to make an adapter and take out a small loan.
Also used one similar to #2021 those worm gear rotating heads are pretty nice to have for a big heavy engine.
http://www.southern-tool.com/store/o...ne_stands.html
