Engine stand that allows flywheel and clutch access - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 08:45 PM
I am building a SBC for installation in a Jeep conversion project but the engine stand I have, and most eveyone I see grab the engine on the bell housing end.
I need to install a flywheel, clutch, check bell housing for run out to the crank, etc. but can not do that on the current stand.
Does somebody make a stand that comes off the engine mount locations and ?? to allow access to the back end of the engine?
Old 04-04-2013, 09:12 PM
sedanbob's Avatar
Engine storage stands usually allow access to the flywheel/clutch. The use the motor mount holes in the block, and a couple of the bellhousing holes in the back. Here's one: Small Block Chevy Engine Storage Stand - Speedway Motors, America's Oldest Speed Shop
The Following User Says Thank You to sedanbob For This Useful Post:
WICruiser (04-04-2013)
Old 04-04-2013, 09:24 PM
Great, exactly what I was looking for.
Thanks
How can I turn the Flywheel to get access to convert bolts BestGeneration67 Transmission - Rearend 14 04-16-2012 08:43 AM
clutch and flywheel 80camaroguy Transmission - Rearend 4 04-12-2012 07:54 AM
Engine Breaking Stand Running Engine Test Stand sloughbum01 Garage - Tools 5 01-06-2012 10:55 AM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 07:20 PM
Starting Engine on stand-Flexplate or Flywheel? mrevil Hotrodding Basics 14 02-03-2006 03:02 PM
