Engine stand bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2007, 02:27 PM
Engine stand bolts
Hello,
About to remove Chevy 350 small block. Bought an engine stand - Question: What size(length) /type bolt do I use to secure the block to the stand? Thanks!
Old 05-26-2007, 03:41 PM
406 ss monte's Avatar
eat a beaver, save a tree
their a 3/8 coarse thread bolt. measure your engine stand & add about 1/2 or 3/4 more to it for the bolt length.
Old 05-26-2007, 04:53 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Make sure you use grade 8 bolts.
R
"SlowRide66"
"Illegitimis non carborundum"
Old 05-27-2007, 08:28 AM
bondo's Avatar
R
Why,..??....
Grade 5s,.... or even grade 2s will hold a motor on a stand till 'ell Freezes over......
Old 05-27-2007, 08:34 AM
3/8th bolt 16 thread ( NC ) grade 8 bolts cost only a very small amount more ... When in doubt ... make it stout
Old 05-27-2007, 09:11 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
Originally Posted by bondo
Why,..??....
Yes they will, they will also snap off in your block.
Old 05-27-2007, 09:33 AM
We have used standard grade 5 bolts on engine stands for over 20 years. Never an issue.
Old 05-27-2007, 03:46 PM
Rob Keller's Avatar
Wiki Edits: 38
Bigger is always better I M H O unless it comes to women.
It would be a real shame to have to replace your oil pan / valve covers {which ever way you got it turned} Because of a stupid bolt.
I use grade 8.
Grade 5 might be OK for the bell housing bolts because there are 6 of them & ... & motor mounts to hold the engine in place.
There is a lot of stress on the motor stand & the weakest point. again IMHO is the 4 bolts going from the stand to the block.
Grade 5 might work just fine but I would not use them again for the same thing.
Here is another piece of advise
Don't buy your bolts from Home Depot or Lowe's .
R
"SlowRide66"
Old 05-27-2007, 05:06 PM
Wiki Edits: 31
grade 5 will bend under high stress
grade 8 will break under high stress
in this case, grade 5 is actully safer.
Old 05-27-2007, 07:24 PM
FEDDO's Avatar
bolts
I think it would be doubtful for 4 bolts to break. I even have one stand that only has 3 legs.
Old 05-28-2007, 08:42 AM
bondo's Avatar
Ayuh,........
And Pennies will Quickly turn into Dollars..............
I'll still be using Gr5s..............
Old 05-28-2007, 09:11 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I recommend AGAINST grade 8 for reasons already mentioned. Grade 8 is superior in items of tensile strength; that is to say where the force is parallel to the length of the bolt. U joints, headers, axle brackets, wheel studs, etc. Grade 5 has a slightly lower tensile strength but its much more malleable. Grade 8s don't bend, they break. Grade 5s will bend and thats a good thing since most of your weight on an engine stand is shear weight... and the tensile strength of grade 5 is waaaay more than sufficient on an engine stand.
I used to think that more is better, but when it comes almost everything in the automotive world, RIGHT is better. Everything has its application, and hard brittle bolts like grade 8 have broken on me before in engine stands and engine lifting.
If you don't believe me, try lifting an engine with a long grade 8 bolt. It will break. But, if you have a shorter grade 8 bolt that you can torque down against the chain, it has a chance because its under tensile pressure and it gets shear strength from the fact that its wedged against the block and can't move. Now do the same test with a grade 5 and the long bolt will just bend.
That was my long winded way of saying; use grade 5 and you'll be happy. Use grade 8 and they'll probably last forever, but if you drop a box out of the rafters on the engine a grade 8 might snap, but a grade 5 will just deform. Ask me how I know. I had two grade 5s and two grade 8s in my Caddy 500 on the stand. The box of toys I dropped from the rafters sheared the grade 8s leaving the engine to hang on the mangled grade 5s.
Old 05-29-2007, 08:11 PM
Why not HD or Lowe's? Lowe's has Grade 5 & Grade 8 bolts if you look in the right drawer. I definitely would NOT use their standard stuff for anything other than loose ballast. I broke a 1/2" standard-grade bolt from a real hardware store with hand wrenches, and I didn't even use my feet.
Old 05-29-2007, 08:43 PM
curtis73's Avatar
Wiki Edits: 16
I love that aisle of drawers at Lowes!!!! I swear I get half of my car parts at lowes these days
Old 05-29-2007, 09:24 PM
Heck, I found some 1/2"x20x3" Grade 8 cad-plated bolts to replace my constantly-breaking bathroom sink faucet handles in those drawers, not to mention some fender washers & felt mirror pads to cushion the door panel of my POS Cadillac from the deck screws that now attach the panel to the door. It's an "engineer"'s heaven, for sure.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 01:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 08:50 AM
question for any engine builders out there mopar72 Engine 7 11-06-2005 04:06 PM
