Engine stand capacity - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2004, 06:43 PM
New Member
Looking at an engine stand at the local auto parts supply store. Says it holds up to 750 pounds. Is this sufficient for a small block chevy engine? How much does one generally weigh with all the standard components?
Joe
Old 06-29-2004, 07:01 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Usually 550+ lbs.
Ive used 3 and 4 leg stands, but both seem ok for a sbc. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 06-29-2004, 07:30 PM
unstable's Avatar
Murderator
Last journal entry: Brackets, Stories and the future
the 750lbs stands are more than enough for small blocks. I have my big block on one now. I checked standard weight of a fully assembled big block before purchasing and I think it was 685 lbs.
Only thing is there's nothing on my stand to support the motor at the front, which kind of sucks because the motor bobs up and down and it makes the entire thing really unstable.
Maybe I'll modify it.
Old 06-29-2004, 07:35 PM
New Member
Thanks for the replys! I am taking a stab at my first rebuild. Expect to hear a lot from me in here.
Thanks again!
