-   -   engine start up ? (http://www.hotrodders.com/forum/engine-start-up-224472.html)
39chevy 09-28-2012 06:23 PM
engine start up ?
What oil should I use to start up (1st) time motor? I have heard all kinds of stories, please advise, thanks Dana
39chevy 09-28-2012 06:29 PM
engine start up ?
cobalt327 09-28-2012 06:45 PM
Fresh rebuild or an engine that's been in storage, or ?
Priming the oil system, using the correct lubricant additives, coating the cam lobes/lifters w/break in grease, etc. are all important. If the cam is new the engine cannot idle for about the first 30 minutes, engine speed varying and above 2000 rpm.
A page w/info on prepping/starting a rebuilt engine can be seen here.
Good luck.
cdminter59 09-28-2012 07:04 PM
Engine break-in
There are several brands of break-in oil. ROYAL PURPLE BREAK-IN OIL, Brad Penn BREAK-IN OIL, COMP CAMS BREAK-IN OIL. I like the Royal Purple line best. After break-in they have a High Performance Street Motor Oil with a high level of zinc/phosphorus anti-wear additive.
Ruthlessmr 09-28-2012 09:05 PM
what motor ?what cam?etc..rotella t 15w40 cam break in additive
zinc additive
