engine start up ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2012, 06:23 PM
engine start up ?
What oil should I use to start up (1st) time motor? I have heard all kinds of stories, please advise, thanks Dana
Old 09-28-2012, 06:29 PM
engine start up ?
Old 09-28-2012, 06:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Fresh rebuild or an engine that's been in storage, or ?
Priming the oil system, using the correct lubricant additives, coating the cam lobes/lifters w/break in grease, etc. are all important. If the cam is new the engine cannot idle for about the first 30 minutes, engine speed varying and above 2000 rpm.
A page w/info on prepping/starting a rebuilt engine can be seen here.
Good luck.
Old 09-28-2012, 07:04 PM
Engine break-in
There are several brands of break-in oil. ROYAL PURPLE BREAK-IN OIL, Brad Penn BREAK-IN OIL, COMP CAMS BREAK-IN OIL. I like the Royal Purple line best. After break-in they have a High Performance Street Motor Oil with a high level of zinc/phosphorus anti-wear additive.
Old 09-28-2012, 09:05 PM
what motor ?what cam?etc..rotella t 15w40 cam break in additive
zinc additive
Engine does not start on N rack Electrical 11 05-21-2010 02:52 PM
cant start engine 1969NovaSS Engine 2 07-11-2005 08:55 PM
engine start up 406camaro Introduce Yourself 1 11-27-2004 08:06 PM
Engine start up rock141b Hotrodding Basics 1 05-13-2004 12:52 AM
Engine Start up Screwy Lewy Engine 3 06-21-2003 06:26 PM
