Engine start up problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2014, 11:01 PM
I am trying to start my engine for the 1st time since rebuild. It cranks but won't fire and appears like it's not getting fuel. It's a 302 Ford, mechanical fuel pump to Edelbrock 4 bbl. I am pretty sure I set he initial timing right and wired the engine correctly. Can anyone give me some advice here as to what are the potential causes.
Old 04-28-2014, 11:04 PM
vinniekq2's Avatar
pour a table spoon of gas down the carb
The Following User Says Thank You to vinniekq2 For This Useful Post:
steng (04-29-2014)
Old 04-29-2014, 09:52 AM
Engine start up
Thanks for the tip - that helped. Now it is clearly getting fuel and almost starting but not quite. It backfires and spits fuel out of the top of the carburetor. It flamed out the top of the carb once. I am a little spooked right now. Obviously, this is the first time I have ever fired an engine from scratch. Sorry for the dumb questions - just don't want to smoke my new engine, or worse. Any body have any suggestions.
Old 04-29-2014, 10:06 AM
vinniekq2's Avatar
double check firing order.
you are close,but timing is off. hook up timing light so you can set timing and RPM as soon as it fires. get the rpm over 2000 as quickly as possible. set timing around 30 .
Old 04-29-2014, 11:00 AM
302 firing order is different than the HO302/351 firing order.
Correct order is determined by the camshaft.
Old 04-29-2014, 11:46 AM
engine start up
1, 5, 4, 2, 6, 3, 7, 8 counter clockwise for 302. Is this right?
Old 04-29-2014, 11:58 AM
engine start up
How do I know if I am on the correct stroke on #1?
Old 04-29-2014, 12:35 PM
455olds's Avatar
You probably are 180 degrees out. You verify by getting #1 piston to Top Dead Center with both valves closed, that will be #1 on the compression stroke. Good luck
33Willys77's Avatar
Hydraulic lifters? Was the engine primed? If its a flat tappet cam, careful with all the cranking as you can wipe off the cam breakin lube. You may also be 180 off on distributor. ???
Old 04-29-2014, 04:02 PM
engine start up
Thanks, I think I am off 180 degrees. I did prime the engine but it is flat tappet and I am concerned about wearing out the cam with all the cranking. Should I pull the valve covers off to make sure both valves are closed on #1? I am running out of tries before things start to wear down. I assume I shouldn't be having flames shoot out of the carb. That's pretty freaky - scared the crap out of me.
Old 04-29-2014, 04:56 PM
I was off on the timing but have now corrected it. I am sure #1 is at TDC and my balancer is set at 0, rotor pointing to #1 on the cap. Engine is cranking and wants to fire but the backfire is still there and the carb is flaming almost immediately. This is freaking me out.
Old 04-29-2014, 05:20 PM
http://www.crankshaftcoalition.com/w..._a_distributor
Old 04-30-2014, 12:49 PM
Engine start problem
Thanks to everyone who answered and helped out I was able to get my engine fired up. Turns out the problem was the cam I put in required the 351W firing order, not the stock 302 order. Soon as I switched the wires it fired right up. What a tremendous feeling. Thanks again.
Old 04-30-2014, 06:16 PM
vinniekq2's Avatar
go break her in
Cold start problem 97 suburban,new engine. usxtrnr Engine 1 12-10-2010 11:32 AM
No Start Problem BLAZERMAN Engine 5 10-26-2006 01:34 AM
Start up problem Dreadlord Engine 7 04-18-2004 07:59 PM
Where to start on blinker problem? shockers69 Electrical 4 01-24-2004 07:42 AM
hot start problem tnsmith10 Engine 1 09-05-2003 07:03 PM
