You might be talking about the one I built that folds up. The wheels are not meant to move it with the engine in place. It's only meant to move the stand unloaded. (sort of like a hand truck) Chances are the wheels will be changed if need be. They are only on there with some long bolts welded to the bottom of the steel, easy to remove if needed. I have had an small block engine on it already and have moved it with those wheels! It's not complete yet. There is still some tweaking involved. But I will take your suggestion and perhaps change things as needed. Thanks for the input. Keep an eye on the page... Next is the battery tray, a 5 gallon plastic gas tank that I bought at a swap meet with a GM EFI pump built into it, going to bend up a stainless piece of sheet metal for the gauges and such. Lastly is the radiator and electric fan. Thanks for the input! Keep it comin!
Sonicweb's Journal
