Engine starts, won't run.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2007, 10:50 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
when key is released.
Changing the wiring harness in '71 Chevelle, took the old butchered up one out and put newer one in. The engine will start, but shuts down as soon as I release the key. Anyone have any ideas?
Old 09-09-2007, 12:08 AM
njbloodline666's Avatar
I Love VTec
how are your wires connected at the starter solenoid... you need to have the wire for the ignition r side of the solenoid, otherwise its only hot in the start position, which would explain your problem
Old 09-09-2007, 03:51 PM
To clarify the previous post, there are two wires from the ignition switch to the distributor. In the START position the wire provides full battery voltage to the coil for easier starting. In the RUN position (when you release the key) there is a resistor wire that drops the voltage slightly to let the points live longer. Something is wrong with this second wire, either it's broken or mis-connected.
If the wire turns out to be OK, then the problem is the ignition switch, but that's less likely.
Old 09-15-2007, 12:23 PM
Wiki Edits: 647
Thanks Joe, I think I have the handle on it now.
Old 09-16-2007, 10:13 AM
Wiring
Did you change the harness in the column? Is it the original column and you just plugged in the GM connector to it?
Does this car use points of has it been upgraded to electronic ignition such as HEI?
Steve
Old 09-16-2007, 12:07 PM
Chopt 48's Avatar
If you haven't done so take a test light and check the ign wire to the coil with the switch on. if that doesn't show power back track to the switch. Note, the tilt and non tilt ign switches are reversed and won't interchange.
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 09:11 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 08:50 AM
Hotrodders Knowledge Base: Engine Jon Engine 0 11-26-2005 07:17 PM
Verifying engine pedigree... johnnya Engine 3 08-04-2004 07:42 PM
Can you run these engine codes please. Rubberman2003 Engine 5 08-29-2003 04:00 PM
