Engine stumbles - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2012, 12:00 PM
Engine stumbles
Just put a new Holley 670 street avenger carb on my engine.
The car runs pretty well, but I don't think it is still right and maybe someone can tell me what needs to be done.
For example:
I can hold the engine at 2k RPM and with the transmission (manual) out of gear. If I punch the thottle to wide open, the engine almost stalls.
Is this an accelerator pump problem with the carb and something I can adjust?
Or is it a timing problem?
I'm not sure and unfortunately don't know of any local shops that work on old tech engines with carbs.
Old 03-05-2012, 03:47 PM
91camaroRS3.1
well..
not sure if this will help but i had this problem after i rebuilt my own carb for the first time. turns out i COMPLEATLY messed up the gas to air flow mixture..if you bought it new that it allready has been "stock set" but depending on your motor then its not correct. i would suggest going to site and finding a customer service number. they will walk you through how to tune it properly. you float might also be getting to much gas. they will tell you how to do it step by step...hope this help
Old 03-05-2012, 05:17 PM
Richiehd's Avatar
JS-70
Post some more info about what youve got. How did it run before? i dont think I ever saw a holley out of the box be right
Engine stumbles while accelerating fastrehotrods Engine 3 06-29-2006 11:34 PM
engine stumbles 1969NovaSS Engine 12 07-25-2005 04:20 PM
new engine smokes and stumbles redracer64 Engine 4 09-02-2004 04:57 PM
engine smokes and stumbles redracer64 Engine 1 09-01-2004 10:46 AM
Engine stumbles only when I make U turns dion Engine 6 07-27-2002 06:54 PM
