engine support ideas - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2004, 02:15 PM
I need to make up something to support the rear of the sbc while the trans is out. I need to be able to move the car with it like that. Any ideas?
Old 09-24-2004, 07:07 PM
stu stu is offline
They will hang just fine with side mounts.
No other support is needed.
Old 09-24-2004, 08:11 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
can you get a block between the heads and firewall?
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 09-25-2004, 10:47 AM
thanks for the ideas guys, I think I will try to make something to support the back of the block against the firewall. The car has to move over some fairly rough floor and I wouldn't feel too good about it just hanging from the mounts.
Bob
Old 09-25-2004, 03:19 PM
stu stu is offline
You can bounce it over very rough terrain and nothing will happen.
IF the mounts are good to start with.
Remove either the distributor cap or distributor before the transmission comes out.
Old 09-25-2004, 08:37 PM
put in the 2 bottom bellhousing bolts and rest them on a bar straddeling the framerails
