Engine surges - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2006, 03:53 PM
Engine surges
Hey guys, this is deno with the 355 engine 671 blower. I have a question about engine surge at idle. Would it be the timing or carb adjustment ? Thanks deno---
Old 08-29-2006, 07:24 PM
surge
Are the centrifugal weights locked in the distrubutor? if not they most likely should be
Old 08-31-2006, 08:06 AM
engine surge
Hey halfprice 5 Do you mean lock out my Dis. advance ?
Old 08-31-2006, 12:40 PM
surge
Yes, try putting a good(one that will allow reving the engine a bit) and watch your timing. I'll bet its bouncing around. If you lock the weights down and it stops surging you could use one of the electronic distributors that advances electronicly rather than mechanical advance.
MSD of course has a box to do it, and it will do boost retard & NO2 activation if you want more power. I think they even have a dist that uses electronic advance that has a screw driver adjustment on the side for a simple drop in solution.
Old 08-31-2006, 01:10 PM
does the carburetor have boost referenced power valves?
henry @ oles
Old 08-31-2006, 01:31 PM
surging could be caused by a lean mixture.
Old 09-01-2006, 06:39 AM
engine surge
Hey guys, The carb's are 650 Demon blower carb's and the engine does run rich, not lean. I did notice that the timing does move around some. I'll lock out the advance halfprice5, and see if that works. Thanks guys. deno----
ENGINE BALANCING NAIRB Engine 22 01-23-2016 02:44 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 01:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
question for any engine builders out there mopar72 Engine 7 11-06-2005 04:06 PM
