Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine surging?
Thread: engine surging?
Old 07-19-2005, 01:32 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
It could be the fuel or spark system. Lack of fuel can cause missing and surging. Check the fuel filter and the fuel pressure. Go over the entire ignition system, do a spark test, if the spark is yellow then it`s weak, you should be able to track down the problem from there.
