Engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2008, 03:18 PM
Engine swap
Have 3, 50's restored T-Birds. A 56, I want to do a 5litre engine and tranny swap, has anyone attempted this and can anyone shed some info as to were one might find ready made engine mounts/kit if available, for such a swap.
Old 07-25-2008, 04:21 PM
There is a bunch of them out there, with and without fuelie. The engine looks like it belongs there. Lots of hood clearance.
I haven't done a Bird, just Fairlanes and Falcons, so I can't even tell you which oil pan you need.
But hey, it is just a Ford, so dimensions are pretty much the same forever. It has to be simple and pretty easy.
I'll bet you'll really like it if you use a fuelie 5.0 HO.
Old 07-27-2008, 02:20 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
"I'll bet you'll really like it if you use a fuelie 5.0 HO."
Yep, 225 hp and dead-nuts reliable. I googled for the detailed info of such a swap, but came up empty.
Old 07-27-2008, 05:15 PM
I ran across an article on the net that said that the 68 Ford Fairlane was manufactured in Argentina from 1969 through 1981 with the Y block 292 engine in it. (can't find the link right now)
Maybe that speaks volumes for this "reverse" engine swap.
Old 07-27-2008, 05:53 PM
JeffB's Avatar
Check out www.fordbarn.com late model several of the guys have done the swap.
Old 07-27-2008, 05:54 PM
http://en.wikipedia.org/wiki/Ford_Fa...(North_America)
Ford Fairlane in Argentina
The Argentine Ford Fairlane.The four-door sedan of the 1968 body style was built in Argentina from 1969 to 1981 under the Fairlane name with three equipment packages: Standard, 500 and LTD. The car was similar to the American model except the engines. There were two options: a 221 CID 6-cylinder with 132 hp, and the old 292 CID "Y-Block" V8 which had been last used in the 1964 F-Series truck; it was rated at 185 hp. In 1978 the LTD "Elite" option was introduced as the most luxurious car of Argentina. By the end of production in 1981, almost 30,000 Fairlanes had been made.
Old 07-27-2008, 06:04 PM
Here's a forum
http://forums.thunderbirdforum.com/a...-2227.html.htm
53 Packard Clipper Engine Swap? 53packard Engine 16 07-06-2010 04:32 PM
Engine swap for Blazer S10 ducktruck87 Engine 31 07-01-2010 08:44 PM
engine swap for S-10 Andrew7dg Engine 33 04-05-2010 07:08 PM
Engine Swap for Crown Vic edge Engine 12 11-03-2009 09:38 PM
Engine Swap for 1948 Ford driver fudggj General Rodding Tech 9 06-08-2008 03:21 PM
