Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine swap?
Thread: Engine swap?
Old 07-07-2012, 12:55 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by terryhelms76 View Post
I think it is the factory rad. that came on the car. They raised the hood 5 inches when they put the BB in but I put it back to the hight it ws before for 2 reasons one it was to high in the back barely could see over it and 2 I like the slimmer look. They also covered up the twin ports on front of hood but I cut those back out as well. Can I take the fan Off and just run electric fan?????
Yes you can remove the fan and replace it with a electric fan, but i wouldn't recommend it a good stock mechanical fan with the cltuch will do a much better job, IMHO and make sure if it still had the front air dam under it if it's gone it will run hot also.
Cole
