Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine swap
Thread: engine swap
Old 12-28-2012, 07:02 AM
timothale timothale is offline
Wiki Edits: 27
all ford
A Fe 390 427-428 will bolt in with factory mounts. I can't remember for sure which way to turn the mounts,, I did the Y block to Fe, use the same motor mounts either switched left to right or turned them around BUT no new mounts required. and I think a 460 will bolt in with the correct factory mounts.
