engine swap 1948 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2010, 10:15 AM
I just purchased a 48 Ford F1 with the original flathead and manual trans. this is for my wife, and she won't drive a manual. i am looking at swapping out the engine and trans. with a 302 with AOD trans. does anyone know if the 302 will fit without to many modifications ?
Old 12-08-2010, 12:09 PM
35terraplane's Avatar
engine swap
I just sold a 50 F-1, it had a flathead in it, but I have a 5.0 in my 33 Ford and a AOD. the motor will fit, well for that matter both will, but like my 33 the F-1 has a pretty flat floor, with the AOD you will more than likely have to put a hump in the slope of the floor. I had to in my 33 seems the AOD is a little bigger, but it was no big deal.
Oh welcome to the site. Someone out there i'm sure has but that combo together in an F-1 and would know more. But I think it would fit.
35terraplane Bob
Old 12-08-2010, 12:53 PM
327NUT's Avatar
35 is correct, the sbf is probably the smallest V8 made, if it doesn't fit nothing will. Gonna take some fab work but thats part of the game...have fun.
Old 12-08-2010, 02:46 PM
Either she needs a different truck or you need a different wife.
No, a 302 will not mount with out a lot of modification to the frame, in the most simplistic terms the mounting of the flat head and the Windsor are completely different. This is not an overly complex job but it is a fairly large one, break out the Saws-All and the welder.
The engine compartment and transmission tunnel are large enough to accommodate the 302 and AOD. You'll need a modern rear axle to handle the power and introduce an open drive-line.
Bogie
Old 12-08-2010, 04:21 PM
engine swap
Bogie
I don't think anyone that has ever built a street rod took the engine and transmission out, and exspected a different one to bolt right in. People put SBC, or BBC, in Fords everyday, and I'm sure Henry never built them so they would fit right in. So I think that a SBF and AOD will fit in that F1, just as easy as one fit in my 33 Ford. I'm not sure, maybe wrong, but I thought someone posted a SBF is lighter and a little shorter, than a flathead, again I could be wrong. But I do think he will have to make a little hump for the AOD, All depends how low the engine sits, and how far forward. I had to put a pretty big hump in my 33/
35terraplane Bob
Sometimes too much to drink,
is still not enough.
Old 12-08-2010, 09:52 PM
327NUT's Avatar
Bogie...I think "fab work" means just that, nothings going to just fall in and bolt right up.......geeez.
Old 12-09-2010, 07:34 AM
engine swap
thanks, for the advice, i expected some fab, was more concerned with the sizing.
Old 12-09-2010, 10:44 AM
1948 Ford
That will fit in there nicely, and still have room to work on it. Good luck, have fun, and post some pictures.
Bob
The voices in my head may not be real,
but they have some good ideas!
Old 12-09-2010, 05:42 PM
Cape Cod Bob's Avatar
I kinda agree with "Oldbogie". How excited is she about driving when the auto is in. It may be she will want power steering then, etc., etc..
What could be more fun then driving an old stick flattie ?
Old 12-09-2010, 06:32 PM
It is not a hard swap, you have to cut out the front engine mount and mid cross member that the trans mounts to and with that the brakes will need to be remounted but there is a pedal mount and master/booster assembly that you use a few existing rivet holes from the old cross member as well as drilling a few new ones. The floor will clear but if you want to the center panel comes out and would be pretty easy to modify if needed. I had to replace the floor pan in the front of the seat on my 51 F1 so when building a new one I changed the center to fit the trans a little better.
There are several places to get the engine side mounts from and a few companies that make trans cross member kits if you don't have the equipment to build one. You can see some pictures of my truck here. http://good-times.webshots.com/photo...03518843CAHgny
You have a good rear in that truck that will not break with a SBF street engine in front of it and has an open driveline so all you need to do with the driveshaft is get it shortened and have your yoke installed with a bastard U joint.
If you wants to add power steering and keep the straight axle the Toyota truck box is supposed to fit and work with a little modifying of the column and a few holes drilled.
Ford trucks.com has a forum section for these trucks as well.
Hope this helps, Mike
Old 12-09-2010, 08:23 PM
techinspector1's Avatar
Wiki Edits: 326
I don't know what all the fuss is about. Bolt an auto up to the flatty....
http://www.transmissionadapters.com/fordflathead.htm
An 8" from a Maverick will handle the rear end chores.
Old 12-10-2010, 06:24 AM
thanks
thanks for the info Mike. I have tried to get her to drive a manual with no luck. better to have her comfortable than crash, yea she would want a diamond shifter knob if see could get it too.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 07:06 PM
ford ranger engine swap frank24 Hotrodding Basics 6 12-07-2005 11:11 AM
94 to 95 Ford Taurus engine and trans swap 406chevelle Engine 6 11-20-2005 02:14 PM
engine swap 5.0L / 51 ford truck hubcap Hotrodders' Lounge 2 09-23-2002 09:04 PM
