Engine Swap for 1948 Ford driver - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2008, 08:10 PM
Greetings to all…
I am building a 1948 Ford for a driver. I want to put a later Ford engine in it using the stock 48 transmission and 3:56 rearend – my first choice is a 155hp 250 Ford six that I have out of a 1970 Maverick – The motor I have is a very good runner, reliable, and descent on gas. Three questions:
1) Has anyone made this swap?
2) Will this use the same engine to transmission adapter as a small block Ford 302 V8?
3) Where can I get an engine to transmission adapter for this swap?
Thanks for replies.
Old 06-03-2008, 08:36 PM
WELCOME to HOTRODDERS.COM ...
I see this is your first technical post. I believe that the Maverick six cylinder may be too long for your 48 Ford engine compartment ... without firewall cutting. I installed a 283 Chevy engine in a 48 some years back. I had to use the early short style water pump and even then, it was a tight fit. I know that the six cylinder should be longer than the 283.
Wilcap is one of the oldest, most well established engine/transmission adapter manufacturers I know of ... and the SBC to early Ford is one of their best sellers. They do NOT list a Maverick style 6 cylinder to early Ford transmission adapter.
http://www.wilcap.com/webdoc8.html
Maybe another one of our members has more information to help you.
AGAIN ... WELCOME
Deuce ... Moderator
Old 06-03-2008, 08:38 PM
Wiki Edits: 31
Being the 250 uses the SBF bellhousing bolt pattern, an adaptor for a SBF will work.. www.speedwaymotors.com should have it in the flathead section...
but if it's a 144-200, it will not work because the bolt pattern on those is all togther diffrent.
Old 06-03-2008, 08:42 PM
Wiki Edits: 31
][/I]
The Maverick 6cyl is 37" measured from the the length of deck surface
Old 06-05-2008, 06:35 AM
I agree with the above; you will surely have problems with the length of the 6 cylinder. Find someone to sell it to or trade it off for a 289 or 302. You'll have an easy swap, and be much happier with the overall performance.
Old 06-05-2008, 08:23 AM
Wiki Edits: 31
it's actully approx the same length as a 302 when you include the water pump on the 302, it's not very long at all. Ither 34" or 37" ( it's 1 or the other, but can't remember which ), I measured mine 1 yr ago when I rebuilt it just to see, then compared it to a 302.. 250 water pump sits in the block, so it does not add to the length much at all.. it could very well fit just as good as a V8
Old 06-05-2008, 09:37 AM
And Ford did install it's own 6 cylinder engine in 1948 Fords. I believe that the 250 six would labor fairly hard trying to pull the 48 Ford along but who knows ... with the low gear ratio in the rear that the 48 Fords came with ... it may be OK
Old 06-05-2008, 09:54 AM
Wiki Edits: 31
The 250's are great at producing low end torque and the 1970 250 is by far the best 250 you can find, as it has a 9:1 compression ratio along with 1 of the better cyl heads Ford put on them.. 155 Hp @4k RPM 240 Ft/lb at 1,600 RPM. I don't think it will have a problem. BUT.. if it was a later 250, after '70 the compression ratio's dropped down to 8:1 in a short period they were barely making 90 HP. and those engines do need help, even though some of the later engines have better flowing heads than the '69-'70 250 head, the chambers are bigger and therefor they have a lower compression ratio.. but you can take a later cylinder head and mill it enough to match the old 52cc chambers the '70 had ( approx .060-.070 off the surface ) and it will wake the '70 engine up.. later cylinder heads were 62cc. '70 and down were 52cc.. guess I'm just a 6cyl guy
Old 06-08-2008, 03:03 PM
Many thanks for replies so far...
Thanks for the replies so far. Has anyone actually ever made or seen this swap before? Also not much luck in finding the small block Ford/302 adapter to the stock 48 transmission. Bentdsens says that the adapters have not been produced for some time. Also did not see them at Speedway. Anyone know where the small block Ford/302 to stock 48 transmission adapter is currently being offered? Have been watching ebay but no luck yet. Thanks for help...
Old 06-08-2008, 03:21 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Hate to rain on any ones parade but went thru this quite a while back and found it turned into a zoo with finding adapters and all the pieces we needed..Wound up putting a 302 with a C-4 automatic and a ranger pickup rearend in the 48..Worked real well and tho I do not recall what the mileage was it did not seem to be all that awful..Best part was that we did not have to split any wishbones or any of that..Kept it stock height and for all the world to see the car is just a well preserved 48..
Sam
Old 01-20-2016, 08:57 AM
I have 48 Ford Coupe with a Chevrolet 350, GM tranny and rearend. I want to put a 302-351 in it with a c-4 or c-6 and 9" rear end. How much trouble am I looking at and has anyone done this before? It has an aluminum radiator. Is there a 9" with disc brakes that will bolt right up with no modifications?
Old 01-20-2016, 09:46 AM
Wiki Edits: 3
One this is a very old thread and two it is considered rude to jump into anothers thread.. Please start your own thread..
Sam
Ford FE engine in a Shoebox Ford Harley Monster General Rodding Tech 3 03-01-2008 01:17 PM
Calling All Ford Guys........ pulling engine, one shot??? biggeazy-e Engine 8 05-02-2007 10:28 PM
ford ranger engine swap frank24 Hotrodding Basics 6 12-07-2005 11:11 AM
94 to 95 Ford Taurus engine and trans swap 406chevelle Engine 6 11-20-2005 02:14 PM
engine swap 5.0L / 51 ford truck hubcap Hotrodders' Lounge 2 09-23-2002 09:04 PM
