Engine Swap 1987 Pontiac Firebird V6 to V8
I have a 1987 Pontiac Firebird with a fuel injected V6. What would it take to swap it out and put in a V8?
Does it have to be a fuel injected V8? Does it have to be controlled by a computer, or can I build a V8 and put it in and be good? What Pontiac V8 would you reccomend? Does Pontiac and Chevy intermix? |
I have it pretty much planned. I've been messing around with the dyno software, testing out cams. It's definitly makes the picture clear when it comes to which cam you choose. You can see right on the graph where you get most of your HP/TQ. Pretty Darn COOL!
Did I mention I have to save up the money for the 383? I have a 1987 Pontiac Firebird with T-Tops that I was thinking about selling. But then again I think hmmm. Maybe I should put all that money in the Firebird. Less work Would a Chevy 383 fit in the Pontiac? Can I use the manual transmission? Probably not with the Chevy but what about a V8 Pontiac. I'm not that familiar with Pontiac V8's. I'm mostly a Chevy and Oldsmobile fan. |
What makes a Oldsmobile 455 a 425? Or should I say what makes a 425 a 455? I have one of these blocks in my shop.
When I took the Piston to Napa to get a new piston for my 455 Olds, they said these pistons where for a 425. That was 12 years ago. What is the difference and would that work? This is fun... |
I did this swap in the past and if you don`t have a V8 donor car, then I usually say don`t bother. The holes for the mounts are already in the frame, all you do is get the mounts for a firebird or Z28 V8 car of the same year. You`ll need V8 front coil springs, crossmember, radiator and etc. if the car has tops and you plan to add a V8 with any kind of power, you`ll have to add sub frame connectors otherwise it`ll twist the body resulting in a broke windshield and a passengers side t top that won`t lock back into place. You`ll also need to install a stouter rearend. This swap involves a bit of work and gets expensive, not trying to be discouraging, just trying to give you a heads up on what to expect.
Where do you get most of your Pontiac Firebird parts? Stuff like replacement consoles and parts? I'm thinking if I rebuild my 455 stock, that I should have plenty of power to move that car. What do you think?
How about mods for a V6? Do they make them?
There are lots of mods for the v6's , just reading thru one of my recent car mags(HORSEPOWER)where guys are getting up to 700 h.p. out of them,pretty pricey,but their doing it.
I would look into modifying the v6,the money you would spend on the changeover to a v8 could be spent on some goodies for the v6. |
Oh and on these cars subframe connectors are a must even without alot of power, the unibody flexes alot. Also if you build an engine with any power a T-5 shouldn't be used if you are going to drive it hard. Some take up to 350 HP others blow at 200 its hit and miss (I'm also guessing big tires that get lots of traction can make the difference) As far as rear end you could be fine with stock but I wouldn't take the chance. Some guys upgrade the 10 bolt internals, others get australian 9 bolts and others just cop out the money for a 9 inch or 12 bolt. |
The Firebird has 223,000 miles on it so a rebuild is probably not a bad idea. It seems to have plenty of power, but if I rebuild it, I would like to add some parts to make a little more power. Not so much power that it will break the windshield or screw up the left T-Top. ![]() I see the subframe connectors, they run $226 and don't look to bad to put on. Last edited by bccsrc; 01-15-2006 at 06:08 PM. |
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| Engine Swap - 64 Galaxie | Billy Boy | Engine | 5 | 07-21-2005 02:49 PM |
| help with v6 to v8 swap | bigt6599 | Engine | 7 | 09-27-2003 01:39 PM |
| 1994 pontiac firebird engine swap | john34683 | Engine | 1 | 09-16-2003 06:31 PM |
| 454 engine swap | joes stude | Engine | 1 | 07-17-2003 08:12 AM |
