engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2002, 03:47 PM
New Member
Post engine swap
have 57'ford that has a 390 ford in it,it's no good,so i have a 289-c-4 i would like to use,any one r ver did one,what mounts do i need ? will it work? thanks
Old 09-12-2002, 06:29 PM
woodz428's Avatar
Troll Hunter
Post
The chassis from '57-'64 are vitually identical. I swapped a small block into a '59 Edsel last year using stock '63-'64 289 Galaxy mounts, it had a fordomatic 2 speed and I used a C-6 and had to notch the tranny crossmember (if it has a cruiso it should work with out modification)
Old 09-12-2002, 08:31 PM
BigBlockBabe's Avatar
Missing You
Post
You'll need different motor mounts. The 390FE is a different family than the 289.
Old 09-13-2002, 03:46 AM
woodz428's Avatar
Troll Hunter
Post
Yes, that's why you use the 289 mounts from the stated years.
Old 09-13-2002, 12:22 PM
New Member
Post
57 ford has 2 holes for mount bolts,I believe to 59. 63 has 1 or maybe the other way around been a while since I've worked on mine.S/T
