Engine Swap 350 to 454 - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Is it worth swapping the 350 for a 454 in a 1968 corvette?
Definely, More muscle the better 3 75.00%
I would go for it, what ya got to lose? 1 25.00%
It is to much work for the payoff. 0 0%
No way, the 350 is the best engine 0 0%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
Old 01-15-2007, 10:41 AM
I am trying to do a swap from a Chevy 350 to a Chevy 454 in a 1968 Corvette. I was wondering if it is worth doing and what actually matches up. Like Does the bell housing match at the tranny and engine? Do the engine mounts work the same etc. Thank you for your help
Old 01-15-2007, 10:53 AM
yes I would make the swap--there is no substitue for cubic inches,and the car would be more streetable than a warmed small block---everything bolts up, IE; bell housing, motor mounts, ETC.....as it is all Chevrolet---but with a small block better handling---with a big block, more brute torque.
Old 01-15-2007, 11:04 AM
firestone's Avatar
http://teamrfc.gospelcom.net
As for what it takes to do, I am not sure, but for the motor, I would try to find a motor with a set of 049 or 781 heads. If you got new 2.19 1.88 valves installed and use a nice street cam, you could easily reach 450 hp and 500 + ft lbs.
Adam
350 to 454 swap Phoenix Down Engine 7 12-07-2009 04:31 AM
carb 350 engine into a 98 V6 camaro boola Engine 1 12-29-2006 05:10 PM
Camero Engine swap Bugs Engine 14 10-28-2005 01:38 PM
79 Trans Am engine swap to 350 JTedd Engine 1 05-10-2004 03:52 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
