Engine Swap---350 Vortec - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2013, 07:22 AM
Hey guys,
I'm in the process of swapping a 350 Vortec into my 98 Chevy 3500 pick-up. The truck initially came w/ a Diesel engine. I have the complete wiring harness, computer, & fuse box for the vortec. I've been told that there are only 8-10 wires that need to be connected in order to get this set up to work properly. Does anyone have any direct knowledge on a swap of this nature??
Thanks
Old 07-25-2013, 08:36 AM
jokerZ71's Avatar
Wrench Turner
IDK exactly how many wires are involved.If you have the complete harness & PCM,most of that is plug n play if it's all from the same vehicle.There are other issues tho that you are gonna have to address if you haven't already.#1 bein the fuel system.You are gonna need an intank fuel pump capable of @ least 60 to 65 psi along with the proper fuel lines & wiring.The easiest thing to do is get a tail lite harness from a like model gas vehicle & swap it out.It will have what you need for plugs & wire hookups.You may need a tank or @ least the sending unit assembly.You may also have some instrument panel changes to make.If you have a tach,the diesel tach runs off the alternator & you have the glowplug circuit you may have to bypass or work around.I'm not positive,but,I think the diesel TC is different than a gas & there are some differences in transmission valvebody calibrations.You may have changes there to make as well.
Vortec Engine Swap Problems 5700 350 capps Engine 22 01-28-2016 12:06 AM
1998 350 Vortec Swap to 2000 454 vortec Bobbydnovaman Engine 4 12-19-2012 11:19 PM
98 350 vortec engine swap 454 vortec engine swap wiring Bobbydnovaman Electrical 0 12-19-2012 10:44 AM
vortec engine swap help Konman350 Hotrodding Basics 2 02-07-2011 08:31 PM
vortec engine swap 620 dude Engine 4 07-10-2010 01:59 PM
