Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine swap-351m to 351w
Old 08-31-2009, 09:41 AM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Yes, you could use a small block/straight six bolt pattern C6, but you have to change the whole trans, the C6 doesn't have a removable bellhousing like the C4 does. 351/302 Windsor engines won't bolt to 351M/400/429/460 bolt pattern trans.
Still glad you are a Ford man??
