Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine swap-351m to 351w
Old 09-01-2009, 03:55 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by wieber
what if i had a complete 77 t-bird to take the drive train out of? its got a 351w but im not sure if it has a c4 or c6. does anyone know if i could make that work? i know that the wheel base is longer by a couple of inches on my gt
Probably, taking everything from the T-Bird. Motor mounts and frame mounts, trans mount and crossmember, engine and trans, shift linkage and carb kickdown link, and the driveshaft. Everything should be a bolt-in, only thing that might trip you up is needing to change the driveshaft length. Not to be a Dic* but if you can't figure things like this out as you go or lack any automotive experience, you are in over your head, find a friend or someone local to you who knows Fords.
