Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine swap 36 cord to GM V/8 FRONT WHEEL DRIVE
Old 07-17-2012, 12:50 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Major 9issue with the early Cord is that the drivetrain was not all that good even when new so changing to a later more modern drivetrain so the car is usable and driveable can be a good choice. After looking at some images of original Cord cars I thinks something to explore would be using the drivetrain from a late 4x4 pickup such as a Tahoe or perhaps a Dakota with the IFs front axle..I would just blank off the rear shaft on the transfer case and run FWD only. I am not concerned about the axle as we can get those to work fine in the off road deal and using a low pinion axle would keep the ride height in the correct area and the engine/trans/transfer case are all proven units..That may fit a lot easier than any of the other ideas..
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
Jerrycord (07-18-2012)
