Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine swap 36 cord to GM V/8 FRONT WHEEL DRIVE
  #95 (permalink)
Old 08-27-2012, 05:46 PM
Silver Shadow Silver Shadow is offline
Great stuff Jerry.
I had also thought very briefly about using a Porsche transaxle for this conversion, but that has one very major problem, getting the gear linkages back around the engine.
The other thing I don't like about a transaxle conversion would be the fan belt and radiator connections would be up against the firewall. It would just look messy and all wrong.
The tailshaft converted Toranado transmission solves just about all of the problems in a neat way, and all with a mix of completely stock readily available GM parts.
Probably many choices for a front diff, but the biggest problem you will face is finding one with a suitably tall gear ratio that is not about as heavy as the engine !!
The Following User Says Thank You to Silver Shadow For This Useful Post:
Jerrycord (08-30-2012)
