Engine Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2004, 08:18 PM
Engine Swap
I have a 1988 Chevy truck with a 350 TBI engine. I want to swap it for a 1980 carburated 350 engine. Someone told it me it will drop right in ,but I want to know if I need to change to a universal wiring harness. I would like to know what I need to install the engine.
Old 03-29-2004, 08:24 PM
Muncie's Avatar
New Member
You do not need to change the wiring it will all work with your motor, all the senders out of the old motor will work on your new on. You will want to pull the fuse on the computer so that the check engine light dosen't stay on all the time.
Old 03-30-2004, 12:28 AM
Be sure you use a non-computer-type distributor.
Old 03-30-2004, 07:05 AM
BOBCRMAN@aol.com's Avatar
Also you will need to keep the 80 flywheel.
Old 03-30-2004, 07:22 AM
Magikal's Avatar
How can it go faster?
Last journal entry: Been a long Winter
Self contained HEI distributor is one of the best things ever made for a 350 SBC in my opinion. Requires no connections other than plumbing solid 12 volts too it (powered while cranking or it won't start).
