engine swap?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2004, 05:38 PM
stngdrvr's Avatar
New Member
engine swap??
ok i have never done an engine swap on my own before, but its time to. i have a carbd 289 and a fuel injected 302. can i take the fuel injection off of the 302 and put it on the 289. these are both ford blocks and the 289 is bored to 302 with a cam, heads and a few other goods. i wanted to swap because my 302 is gettin up there in the miles and this 289 has more hp anway. somebody enlighten me please
Old 07-04-2004, 07:05 PM
4 Jaw Chuck's Avatar
Remove old engine, installation is the reverse of removal. It's a straight swap no surprises.
— Han Solo
Old 07-04-2004, 08:36 PM
gpeak's Avatar
LOL...The question is will a fuel injection system on a 302 bolt up to a carbed 289! I am not a FORD guy so i don't know, just wanted to clarify that.
Old 07-04-2004, 09:39 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
I think he means just take the manifold off the 289, put the plenum (or whatever kind of intake you have for the EFI) on it, and dump it in, hook up the connections just like you had on the 302.
You know the 289 is a heavier motor right?
K
Old 07-05-2004, 01:44 AM
New Member
you shouldn't have any problems bolting the EFI onto the 289, they are the same block, heads on the 289 should flow worse than the 302, but the bolt pattern and all are the same, only difference between them should be the stroke length
Old 07-05-2004, 07:35 AM
stngdrvr's Avatar
New Member
how much heavier is the 289 than the 302, and i believe he has cleveland heads on it with a cam or something... i can call the guy and let you guys know what he has. Also will the headers i have on the 302 go on the 289?
Old 07-05-2004, 08:09 AM
New Member
just checked my NPD catalog, the part number for the header for a 289 and a 302 are the same, so that shouldn't be a problem, but i would check it out as best you could before you put any money down just to be on the safe side
and this page says that only the late model 302/5.0 motors are slightly lighter
http://www.team.net/sol/tech/engine.html
which makes sense, they do have aluminum intakes and bracketry and stuff
i would think that it wouldn't be light enough to matter, especially since you'll be swapping the aluminum intake to the 289
Old 07-05-2004, 09:50 AM
The engines are virtually identical but I would check for threaded bosses that may not be on the 289, I know for sure there is no threaded hole for the knock sensor. Now would be the time to check while you can drill and tap an existing boss for a bolt.
— Han Solo
Old 07-05-2004, 10:55 AM
stngdrvr's Avatar
New Member
cool... thanks... is there anything else i should know? will my AOD bolt right up?
Old 07-05-2004, 11:35 AM
Wiki Edits: 3
yup
