48 Lincoln conversion
My daughters 86 Town Car is very reliable with its 302 F.I. and 3 speed tranny w o.d.-BUT-the wiring involved to make it work may be daunting.It may be less intimidating(to me at least)once the engine is out and the engine harness is seperated from the rest of the cars wiring.How about a Ford truck rear end?May or may not be too wide.Might be the right bolt pattern,too.I remember reading an article somewhere that the hardest part of doing this swap is that the frame rails are close together-is that right?You are going to gain alot by getting rid of the V-12-never heard anything good said about those motors.
HYi;Thanks for the reply.This is a funny one no OD just the 3 spd auto.Think may go with it anyway!THe opinion seems to be to get rid of the FI and put on a 4 barrel manifold lot less complicated.Apparently the midsize fords Granada etc have the narrower springs.Dread getting into this can of worms but if get it done should have a car you can rely to travel with.No much nicer looking cars than these old Continentals but the old running gear is always a question!Thanks!!
if the gears in the rearend of the 86Town would haul that heavy car then why wouldnt gears that high pull ur 48 Lincoln??? i had mid gears that were in the mid 2's & it pulled my 40 chevy down the road w/o any problem & i could also break the tires loose at a stop sign if i wanted.
here's some page w/rearend widths to help u in the search for a rearend. IF u want to use a ford rearend look at some of the midsize later ford w/the 8.8 rearend or the midsize chevys w/the 8.5 rearends, all will handle that mtr w/o any problems.joe http://carnut.com/specs/frear.html http://www.chevytrucks.org/tech/ifs&rearend.htm http://www.kevinstang.com/Ninecase.htm http://dfwmotorsport.com/Fairlane/9inchrearends.htm Last edited by TooMany2count; 06-08-2006 at 11:15 AM. Reason: mamma told me tooooo |
your rear
Whats wrong with the rear end under it? whats the rasho? It carried the car org. so weight wouldn't be a problem. That car was designed to cruse at 70 to 80 mph. on the road. I'd be think more about having something that would get it going and hole is speed at cruising. I don't think I worry about mileage, after all, you not goin to drive it daily. I do think I 'd go with a O.D. trans. I.m not a ford man, but I did put a 390 Hi-performance A T from a 66 GTA in a 55 ford truck. It was light (had trouble taking off) but it would carry the mail. Carb would be easier to hook up. F.F.T.
Some think that the HV-12 is a POS. Not true! an overhauled engine with clean water passages, rebuilt water pumps and a modern oil pump will eliminate the heating and lubrication problems that gave the V12 flattie a bum rap. The post war V12s can be set up with dual carbs and aluminium heads, they push the big barges around nicely. (they aren't as heavy as you would think, my Zephyr is huge but only weighs in at around 3400.) My smaller V12 does fine both off the line and cruises at 60 as long as you want. (no overdrive on mine yet) They used a closed torque tube and around a 4.00:1 rear end ratio. Many were equipped with Overdrive units. (the Columbia on the early ones and the Borg Warner on the later.) the transmissions are strong and were the desired gearbox for racing back then. Don't be afraid to stick with the original, in the long run you will be happy with it. Another option would be a post war Ford V8 such as an 8BA, it's a direct bolt in. If you are really set on doing the swaparoo for modern, the 302 or 351W with an AOD and a Granada rear end, custom driveshaft will work. How about a 300 I-6 from a truck? They have gobs of torque and are plentiful. (it would look cool under that mile long hood too) Another option would be an independent rear from a Cobra Mustang or Thunderbird, then you could get disc brakes out of the deal. lots of fabrication will be necessary. Take a look over at the LZOC website and the forums there. You will find more info on the H series Lincolns than you knew existed.
| 1996 Vortec Engine Swap - need Help | Adam Mclaughlin | Engine | 14 | 01-03-2005 09:56 AM |
| v6 Engine Swap | millennium | Engine | 3 | 04-29-2004 02:50 PM |
| Engine Swap | pete379 | Engine | 4 | 03-30-2004 07:22 AM |
| Help with engine swap | WILDBRONCO4 | Engine | 2 | 10-19-2003 10:45 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
